Where is my coolant going?
Help we my pennies
I looked in my coolant res bottle and it was empty, so i filled it up, and checked it a few days and it was empty again.. wher is the coolant going?
Im not over heating, so whats the deal? i also have no cat
Modified by BLUE EH3 at 8:15 PM 10/21/2006
Re: Where is my coolant going? (ChinitodeNJ)
if the coolant disappears it could be a leaky headgasket. i had this problem on one of my cars last year and i couldnt fiqure-out where the coolant was going.
Re: Where is my coolant going? (BLUE EH3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUE EH3 »</TD></TR><TR><TD CLASS="quote"> I looked in my coolant res bottle and it was empty, so i filled it up, and checked it a few days and it was empty again.. wher is the coolant going?
Im not over heating, so whats the deal?</TD></TR></TABLE>
THATS THE SAME THING WITH MY CAR!!! i have know idea what it is but today im gonna go buy the leak detector and see if theres a leak... this happen after my car over heated due to a sticking thermostat so it might be the head gasket hopefully it isnt , dont feel like taking it apart..
Help we my pennies
Re: Where is my coolant going? (DragWerks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DragWerks »</TD></TR><TR><TD CLASS="quote">Does the car run hot? Check around water pump and hoses in back of the motor</TD></TR></TABLE> car does NOT run hot
Check for puddles under your car or wet spots underneath your hose connections.
Have someone drive behind you while you step on it. Look for white smoke to indicate a blown head gasket.
Help we my pennies
Re: Where is my coolant going? (sql_civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sql_civic »</TD></TR><TR><TD CLASS="quote">Check for puddles under your car or wet spots underneath your hose connections.
Have someone drive behind you while you step on it. Look for white smoke to indicate a blown head gasket.</TD></TR></TABLE> will check
Help we my pennies
Re: Where is my coolant going? (jmezz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jmezz »</TD></TR><TR><TD CLASS="quote">Be aware of the white smoke... Dissapearing coolant is either a leak or a head gasket..</TD></TR></TABLE> I had white smoke at start up, then i drove it 1 mile with the heat on and the white smoke was gone
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jmezz »</TD></TR><TR><TD CLASS="quote">I also have the same problem, only with the oil.. It takes about a quart a month..But yet I have no oil spots??</TD></TR></TABLE>
check your distributor...
if it gets oil inside of it then your o-ring needs to be replaced...
Edit: should have quoted sorry...
Modified by Striker_1818 at 10:16 AM 10/22/2006
Help we my pennies
Re: Where is my coolant going? (Striker_1818)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Striker_1818 »</TD></TR><TR><TD CLASS="quote">check your distributor...
if it gets oil inside of it then your o-ring needs to be replaced...</TD></TR></TABLE> i def have bad vavlue cover gsket. im bsing about fixin it
It sounds like your head or valve cover gasket.
They're both relatively easy to change, change 'em, see where you are from there.
