Engine conversion help (Integra Type r)
YO wot up !
Im putting an Integra type r engine into my 94 civic dx hatch this weekend, is there anyone that can give me a heads up on wot problems i may run into....
ALSO
i have upgraded my brakes all round to 98 civic vti brakes will these stop this beast
ALSO
Re: Engine conversion help (COLKEOWN)
uhh yeah... anyways to answer your question, make sure that you have all the needed parts such as axles, mounts, shift linkage, ecu, etc.. as for doing the swap itself a couple major problems are the shift linkage roll pin, best bet is to use and air chisel and a punch, next would be the TPS they tend to get in the way so if possible take it off and re-install it after the motor is bolted in... time and patience and use your head and it won't be too bad!
good luck with your "beast"
You will have to wire vtec from the ecu to the engine bay. You need a rear L-bracket if the motor didn't come with one from a 94-01 teggy or 99-00 si.
Not sure which year or usdm jdm type r's had the different axle sizes.
Otherwise pretty straitforward swap.
cman101
08-28-2009 08:14 AM
