The infamous 3rd gear grind and its fix
Swaggylicious
I searched and I only found this
is that the ONLY way to fix it?I mean goddamn,is there a cheaper alternative that will lessen the grind or something?
Unceasing Measure
You can try changing your fluid, but if there's damage to the gears themselves or the synchros, you're stuck having to replace one or both. Sucks, but that's how it goes.
It'll be far cheaper to just buy a transmission that doesn't grind
Re: (cambopheonix56)
Synchromesh will help if its not too bad.. I tried it, but it was too late. I ended up buying a fresh B16 trans. BTW, when they cracked open my old transmission, third gear was in about 10 peices.. but maybe the fluid will help you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cambopheonix56 »</TD></TR><TR><TD CLASS="quote">Amsoil/gm syncromesh will cover the problem up.</TD></TR></TABLE>
Lets stress that
Lets stress that
Re: (pdiggitydogg)
Its not going to bother you driving around knowing that your tranny has a part needing replaced and it could go out anytime? I say replace it, dont cover it up with synchromesh.
Re: (sam21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sam21 »</TD></TR><TR><TD CLASS="quote">hmmmm,how many bottles do I need of this syncromesh?</TD></TR></TABLE>
3, just do a drain and fill. Only like 2.5 quarts comes out.
3, just do a drain and fill. Only like 2.5 quarts comes out.</TD></TR></TABLE>
2.3liters for a B16 tranny
dkim48
Honda S2000
12-05-2005 05:20 AM
