fed up
fed up
I cant get my effin car started. it will start a few times periodicly. ive replaced, fuses, relay, ignition mod. coil..starter seems to work"it makes noises" lol. im totly fed up. can anyone help ? any other ideas?
pce.
pce.
Cool Cool Island Breezes. BOY-EE
Re: fed up (ALL5tar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALL5tar »</TD></TR><TR><TD CLASS="quote">I cant get my effin car started. it will start a few times periodicly. ive replaced, fuses, relay, ignition mod. coil..starter seems to work"it makes noises" lol. im totly fed up. can anyone help ? any other ideas?
pce.</TD></TR></TABLE>
since your starter is "making noises", i doubt banging on the solenoid will work. The car needs 3 things to run: AIR, FUEL, SPARK. You've checked for spark...but what about the other two?
Re: (ALL5tar)
Have a friend turn the key to the "on" position, while you lie on the ground with your ear as close to the fuel tank as possible. If you hear the hum of the pump, then you know that is not your problem.
Re: (maynards_ek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maynards_ek »</TD></TR><TR><TD CLASS="quote">Have a friend turn the key to the "on" position, while you lie on the ground with your ear as close to the fuel tank as possible. If you hear the hum of the pump, then you know that is not your problem.</TD></TR></TABLE>
why not pull out the back seat and listen to it. much safer. check your main relay
93egsi
20
08-26-2003 02:54 AM
Accord15
06-25-2003 09:54 AM
