Hazard Switch.
Hazard Switch.
Hey whats up guys. I have a '95 Civic Hatch CX and I cant figure out why my hazard lights dont light up when i press the switch. If the switch is engaged i cant use my turn signals. when the switch is off my turn signals work fine.
any info would be greatful. thanks in advance guys.
i have the same problme. i dont need hazards tho cuz my car dont break down ya see???... just keep flipping yur turn signals left and right untill u kome to a stop.
Re: (SoHc94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoHc94 »</TD></TR><TR><TD CLASS="quote">i have the same problme. i dont need hazards tho cuz my car dont break down ya see???... just keep flipping yur turn signals left and right untill u kome to a stop.</TD></TR></TABLE>
Yeah i see. I just want it to work. i guess im just a little **** about those little things.
Re: Hazard Switch. (Jussstin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jussstin »</TD></TR><TR><TD CLASS="quote">Hey whats up guys. I have a '95 Civic Hatch CX and I cant figure out why my hazard lights dont light up when i press the switch. If the switch is engaged i cant use my turn signals. when the switch is off my turn signals work fine.
any info would be greatful. thanks in advance guys.</TD></TR></TABLE>
Sounds like you wont be able to let others know when you have won the race.
Sounds like a fuse to me.
Re: Hazard Switch. (dpkelly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpkelly »</TD></TR><TR><TD CLASS="quote">Something's wrong with the switch itself. When you remove the switch, your turn signals also won't work. </TD></TR></TABLE>
well this is a switch from my coupe. it worked in my coupe.
do you knoW what fuse it could be?
Re: (egmatt93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egmatt93 »</TD></TR><TR><TD CLASS="quote">the circuit isnt being completed, try another switch, check ur fuses. let me know if that helps </TD></TR></TABLE>
ok ok thanks for advice. will try this
Re: (Echo7847)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Echo7847 »</TD></TR><TR><TD CLASS="quote">same parts #'s. Sounds like bad switch or wiring issue @ the connector. Most likely the first one.</TD></TR></TABLE>
what do you mean by same parts #'s . . . im gonnna check my switch as soon as my friend gets back from vacation. most likely saturday
Re: (97Ej6mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike »</TD></TR><TR><TD CLASS="quote">Have you checked the fuse yet?</TD></TR></TABLE>
not to sound like a noob. but what fuse would that be. can't find it on the diagram for under dash.
Re: (PhiLLiPDUONG)
Bub, go here:
http://hondatech.info/download...ivic/
and download the 92-95 civic manual. Check the electrical section and you'll find it in there on how to debug that hazard switch. If you can't follow the manual then you shouldn't be posting here. Bring it to a mechanic.
4DRmafia
11-09-2006 09:48 PM
Mleach
18
07-04-2005 07:58 AM
