tps sensor
tps sensor
i have a 93 eg dx and i swapd a ls throttle body and i was told told the tps needs to be reset becuz wen i rev or drive between 3 and 4 1/2 rpms it sputters then opens up and pulls pretty hard so i was wonderin does anyone kno how to reset a tps sensor
1 Post
Re: tps sensor (Team ICU)
the tps is factory calibrated, if you think that you can do better, you must remove the one way screws holding on the tps, replace them with a allen bolt or something else then adjust the tps with a multimeter at closed throttle and open throttle. you can also check your mid way adjustments after those 2 values are set. check the spec in your owner's manual. BUT as far as i remember, all honda/ acura tps values in that year range are the same....
Re: tps sensor (littleredcivic)
What is a multimeter and how do you adjust the tps while the throttle is closed and open. I also have this sluggish problem with my b16. I got this problem after a few days i got my fuel injectors cleaned. Then a code popped up and i hook it up to a scanner and and I got a PO505 Idle Control System Problem.... What is that?
Re: tps sensor (rare Ek)
Multimeter looks like this.
http://cgi.ebay.com/Digital-Mu...wItem
I believe what LRC is suggesting is that you manually try and adjust the TPS so it reads correctly. I wouldn't bother with that cause it seems to complicated. Wiggle this way and that way then tighten it once you got it right.
cazper8890
03-02-2007 08:25 PM
nutball72
11-11-2006 07:14 PM
Achenar
14
07-15-2005 03:27 PM
