Fuel Line Mounting Stud
How hard is it to remove the fuel line mounting stud from the stock fuel rail? I plan to upgrade to stainless fuel lines and would like to use the an to metric adapter vs. the an to banjo fitting. This is on an ITR motor in an EK. Thanks in advance.
AN to metric:
AN to banjo:
AN to metric:
AN to banjo:
Re: Fuel Line Mounting Stud (gotboost562)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gotboost562 »</TD></TR><TR><TD CLASS="quote">No one here has removed or tried to remove the mounting stud?</TD></TR></TABLE>
Re: Fuel Line Mounting Stud (iceman7329)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iceman7329 »</TD></TR><TR><TD CLASS="quote">How hard can it be to place a wrench on it and turn?</TD></TR></TABLE>
Where are you going to put a wrench? Once the nut is removed there is the stud remaining with only threads. You would have to use vice grips or similar to remove the remaining stud.
I found this pic courtesy of -EH3-:
Re: Fuel Line Mounting Stud (SiYouLater)
Could try to double nut it. Spin on one nut and then spin the second one on after it, tighten second on down while trying to loosen the first then use the first nut as the removal wrenching point.
Another option would be to get a second oe fuel rail or aftermarket unit and do the swap out with less risk of leaving your stranded.
Re: Fuel Line Mounting Stud (CarbonizedDX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CarbonizedDX »</TD></TR><TR><TD CLASS="quote">Could try to double nut it. Spin on one nut and then spin the second one on after it, tighten second on down while trying to loosen the first then use the first nut as the removal wrenching point.
Another option would be to get a second oe fuel rail or aftermarket unit and do the swap out with less risk of leaving your stranded.</TD></TR></TABLE>
I was thinking of trying the double-nut trick. I would assume the outer nut has the same thread and pitch of 12mmx1.25?
raidacaipo
09-12-2008 02:31 PM
NsX_CrX
14
01-16-2006 06:25 PM
