head gasket
Old 05-02-2007, 06:18 PM
gsrHB's Avatar
Default head gasket
iight i just put a swap in and theres alittle lick by the head gasket, i was wondering if it is nessacary to replace the head gasket right away or can i just put some rubber selient on it for now till i get some cashe to replace it
Old 05-02-2007, 06:21 PM
Mr.EM1_EK's Avatar
Default Re: head gasket (gsrHB)
whats a lick ? if you mean leak then yeah you should change it asap, before you run into any problems.
Old 05-02-2007, 08:56 PM
gsrHB's Avatar
Default Re: head gasket (Mr.EM1_EK)
does anyone got like a photo guide on how to change a head gasket so i can it as a reference
Old 05-02-2007, 09:26 PM
SiYouLater's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrHB &raquo;</TD></TR><TR><TD CLASS="quote">does anyone got like a photo guide on how to change a head gasket so i can it as a reference</TD></TR></TABLE>
jdmlyfestyle.com
Old 05-02-2007, 09:45 PM
smileycvc's Avatar
Default Re: head gasket (SiYouLater)
dont change it yet. it could just be some oil got spilled and rested near the headgasket. If you did not remove the head or anything there should be no reason why that headgasket is bad. If anything do a compression and or leakdown test.
Old 05-04-2007, 02:46 PM
Cyphear's Avatar
compression or leakdown wont tell you if the HG is leaking oil, that will only tell u if the coolant rings on the HG are broken, but you'd know if that was the case.
Old 05-04-2007, 03:38 PM
sr20b13's Avatar
put some tape on it,
jdmitrdc2
04-15-2009 11:31 AM
zcmotor
15
02-17-2008 10:57 AM
raphael
02-16-2007 10:21 AM
kevinoneill
09-17-2003 05:13 AM
Quick Reply: head gasket
