where is the antenna opening?
my car had an antenna blockoff plate, and now I want to install an antenna. Problem is, I cant find the damn antenna opening, all i know its somewhere by the fuse box. Can someone tell me exactly wehre it is? I want to avoid removing the dash panel
thanx in advance
car:92 civic lx
thanx in advance
car:92 civic lx
H-T White Ops
I don't have the 5th gen manual, but this should be about the same.
http://img407.imageshack.us/im...6.jpg
http://img407.imageshack.us/im...7.jpg
So it looks like it'd be near your dead pedal.
Re: where is the antenna opening? (qwerty07)
It goes up behind the main relay into the actual hollow part of the A-pillar... I don't know how you would put a new one through there without having the cable from the original in place. I had to replace one in a 93 civic LX once and what I did is tie a piece of twine to the antenna cable under the dash right from where I unplugged it from the radio and pulled the cable all the way through the A-pillar to the outside of the car. I then reattached the string to the new antenna cable and pulled it back through to the inside of the car. That insured that the new antenna cable followed exactly the same path as the original antenna.
chrysler kid
18
05-14-2015 07:34 PM
305_DB7ish
03-25-2015 12:52 AM
r3sistance
03-16-2008 08:43 AM
