what is going on!!!
what is going on!!!
my car is a 1993 d15b7 del slo and ive had my headgasket changed 2 times over the past 18 months the last time being 3 months ago and now its blown again, im taking it to a repair shop close to my house that a friend used to work at. im scared to take it back as it seems like hes not doing a proper job, is he not machinging my head? why do my gaskets keep failing after he installs it? could my cyclinder head be in that bad of shape that even machining cany fix it? any help greatly appreicated, i dont know what to do...
Re: what is going on!!! (cdizzle)
Head sounds like it needs resurfacing, probably warped from overheating (Have a reputable machine shop do it)... Hopefully it's not too warped to resurface the head after all of those installs of multiple head gaskets..
Modified by ke98248 at 5:57 PM 6/20/2007
Re: what is going on!!! (ke98248)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ke98248 »</TD></TR><TR><TD CLASS="quote">Head sounds like it needs resurfacing, probably warped from overheating (Have a reputable machine shop do it)... Hopefully it's not too warped to resurface the head after all of those installs those bunch of head gaskets..</TD></TR></TABLE>
This is true but I have seen people strip out head bolts the gaskets will hold for about a day
My friend found a Z6 for 50 bucks we later found out the head bolt was striped
but he lucked out and the head warped its self shut ha can u believe it.
Re: what is going on!!! (civic_jdm16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_jdm16 »</TD></TR><TR><TD CLASS="quote">
but he lucked out and the head warped its self shut ha can u believe it.</TD></TR></TABLE>
What?
What?
welll the guy said he had his machine shop do it? so u think this can be fixed?? should i take it back i means hes done this twice already i dunno wut to do im just throwing my money away
Re: (cdizzle)
take it some were else sounds lie dude might be ripping you off I have changed head gaskets tons of times I can get em resurfaced for about 40 bucks
I think this guy might be screwing you over also there are steps to tightening the head bolts maybe he isn't doing it right and forcing the gasket out of one side..
Swap it.....Just put one of these in your Sol like I did in mine http://www.hmotorsonline.com/s...30021
i cannot swap it i dont have the money i just need to know is my head actuallly ruined? or as long as i get it resurfaced and the gasket installed properly everything will be okay or is there a chance i need a whole new cyclinder head??
does anyone know how much is costs to have a cylinder head pressure tested? and also the cost of resurfacing roughly?
also when doing a headgasket job what other gaskets are needed to be replaced, is it absolutely necessary to replace the intake manifold gasket and valve cover gasket etc? the ones in there now are only 18 months old...
thanks!
thanks!
also which headgasket do i buy for my d15b7? the oem honda or a aftermarket?
is there a different headgasket i can use from say a d16z6 or d16y7/8? "?
Re: what is going on!!! (Sick EM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sick EM1 »</TD></TR><TR><TD CLASS="quote">i think you should take it to another shop they probably are doing a terrible job</TD></TR></TABLE>
also they do sell head gasket sealer at advance auto farts & auto zone, napa
if you can get a hold of a torque wrench take the valve cover off and check the torque settings to see if there right.....
something I have head the other day makes me think
this guy said if you pcv valve is bad it will blow gaskets I think it might be bull spit
because the hose would blow off before the gasket I would think....
JDMlyfestyle
10
11-14-2004 05:42 AM
