Plz Check my work Wireing !!!!!
Ok so i startd to mess with the wires on the DX obd2b harnes i got i need to make it work with the B18c motor
I found this
1.) If reusing a CX/DX/LX engine wire harness you will have to perform these wiring mods to this harness:
a) add wiring for the VTEC Solenoid (VTS) & VTEC Pressure Switch (VTPS)
b) perform the IACV mod
c) add wiring for the Knock Sensor (KS) - IF - using an OBD2 DOHC VTEC ecu or non-reprogrammed OBD1 DOHC VTEC ecu
d) possibly extend the 2nd 02 wiring (if you're using a US OBD2 B-series ecu)
e) perform the OBD2a CKF mod
this is what i have done so far
1. I cut/crimp the dizzy plug and and did this wire by wire following this
https://honda-tech.com/zerothread?id=566618
2. I did they 3-2wire IACV mod just like it shows here
Only one thing in the pic. it shows the 2wire IACV black and green on the JDM harnes is different colors but i wire them proprely (org wire not used ) i did the 2step proces
http://www.ff-squad.com/tech/w...1.jpg
Now for the KS the one on the harnes is a 3wire plug but on the b18 is 1wire.
Do i just run a wire for KS to the ecu conector C slot 3 ??
Do i have to do a CFK mod ??
am planing of runing a odb1 chipd ecu
I found this
Re: (free99)
The KS is never a 3wire on a honda. Its a one wire straight to C3.
If you plan on running a chipped obd1 ecu then you dont need KS or CKF, thats only for obd2 ecus
Arthas
04-23-2012 01:30 PM
93(Civic)EG6
08-04-2007 06:10 PM
ilovemyb16a
05-18-2006 12:58 PM
