eg b16 swap a/c problem
hello all, i have a 1992 civic with a swapped b16. it all runs good so i wanted a/c. since i had the psr bracket i put a gsr compressor in the car and vaccumed it down and charged it with 2 and a half cans of 12oz r134a. when i turn on the system on 4, it dosnt blow cold and the compressor will trip in for a few seconds and then out for about 7 or so seconds the back in again. when i put the a/c on 1 the compressor will trip out and the air will get colder but not as cold as i would expect. i asked some people what to do and they just said put the single cam compressor in but no one ever tells me why. i just figure that a compressor is a compressor whats the problem. anyway. any help will be much appreciated due to the fact that its 100 degrees and raining in florida right now. lol
Re: eg b16 swap a/c problem (blackcrx16)
dont have an idea of the problem of your compressor, but since it is a 92 did your retrofit the r12 to r134a? if you put 2 and a half cans of 12oz that would equal 30oz. normal is between 17.6 to 19.4 oz. i have heard if there is to much freon it will not cool better.
Re: eg b16 swap a/c problem (kevin0405)
if the system holds vacuum and there isn't any leaks i would suggest that you evacuate the system, put the correct amount of charge in and then check it before you start swapping compressors etc.
Re: eg b16 swap a/c problem (305accord)
i understand all this but the probelm i have is that the compressor wont run long enough to cool , it only runs for like 10 seconds max and then trips out and then about 5-7 seconds later it kicks back in and then out for another 10 sec. what could cause this? does the gsr compressor pump more freon than the single cam compressor?
i have the single cam compressor and all just missing the condensor line. what should i do?
Re: eg b16 swap a/c problem (crazyguy)
no i didnt use a brand new one, i used a old one a friend gave me out of his car. his a/c blew ice and he took it apart to change everything( why i have no idea) my old one was clogged up with what looked like mud. black oil and dirt? anywho what do you think?
bugzpimpin
17
10-19-2005 01:32 PM
globlctzn
04-01-2003 11:18 AM
