LSD help.......
LSD help.......
Ok i did some serious searching for a few hours today to try to find a lsd solution for my LS transmission. I looked at the Quafe but wow thats a expensive part. anyways i was wondering if a oem Type R LSD would work does... anyone know? and would it do the job?
Re: LSD help....... (95ProjectEJ1)
If you go with the oem lsd (ITR) your gonna need a type r or GSR ring gear, counter shaft and first gear. Because the ring gear on your LS will not bolt up to the OEM LSD. B16 and B18 (ls) have the same differentials/bolt pattern and GSR's and Type Rs have the same ring gear bolt pattern. Its the same as if swapping a 4.785 final drive and LSD into an ls or b16, You'll need the ring gear, counter shaft, pin bearings and first gear.
SO your best options are to get the Quafe LSD if you plan on keeping your ls tranny. OR the best Option would be is to just find a B16a or ITR tranny with one already installed.
Ek Forever y0!
Re: (DecentCivicZ6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DecentCivicZ6 »</TD></TR><TR><TD CLASS="quote">Seen tons of cable B16a trannys with OEM lsd go for $400....thats what I sold mine for. Why not try and OBX?? only $350 </TD></TR></TABLE>
I agree, the obx are great if you're confident enough to take it apart and re-align the interior components.
I've heard several success stories. They're almost identical to quaifes once you get them apart and re-aligned.
Re: (ek forever guy)
Y not just buy a type r lsd and have it installed?
They are on egay all the time. I bought one that had the ring gear and everything. Granted I had a GSR tranny, but I got all the parts needed, I installed the type-r final drive it came with too......
They are about the same price as the OBX.......
Or this...2000 type-r tranny $1000 on egay.
http://cgi.ebay.com/ebaymotors...ZWDVW
Re: LSD help....... (smileycvc)
Well im running a turbo setup on a cr-vtec and i was told that the ls trans would be a good mate for my motor set-up.
Ek Forever y0!
Re: LSD help....... (Turbo92cx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo92cx »</TD></TR><TR><TD CLASS="quote">Well im running a turbo setup on a cr-vtec and i was told that the ls trans would be a good mate for my motor set-up.</TD></TR></TABLE>
Unless your car makes 800+ hp a long geared tranny isn't likely to be beneficial.
Re: LSD help....... (ek forever guy)
well the motor is a fully built dart b20 block with a full race port built b16 head and im runnig a dual ball bearing t4 60 trim... im mean its not a 300hp car.
really.... i was told that if i ran the ls trans i would have a sick third gear pull. plus they are pretty cheap trans..
Ek Forever y0!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo92cx »</TD></TR><TR><TD CLASS="quote">really.... i was told that if i ran the ls trans i would have a sick third gear pull. plus they are pretty cheap trans.. </TD></TR></TABLE>
Myth.
Having a "sick" 3rd gear pull isn't worth having the slowest B-series tranny there is.
Myth.
Ek Forever y0!
Re: LSD help....... (95DxSi-R2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95DxSi-R2 »</TD></TR><TR><TD CLASS="quote">i'm to sun beat and buzzed to post anything smart
ask bense</TD></TR></TABLE>
Then don't post.
Then don't post.
Ek Forever y0!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95DxSi-R2 »</TD></TR><TR><TD CLASS="quote">5th in the itr/b16 is approx 110 i belief.</TD></TR></TABLE>
You're saying the maximum mph of the 5th gear is 110mph?
Guest
Posts: n/a
i'd say the b16/itr trans is perfect for drag racing sicne it has the shortest gear's out of all b series tranny. Once you start pushing for more hp and faster speeds, u can top out a b16/itr tranny. there have been combos of itr 1st n 2nd, gsr 3rd, itr 4th and ls 5th with a itr lsd final drive, it's just how much power you plan on producing. that is the major question. there my buzz started going away.
Also i just tested it, i have to shift to 5th @ 110mph (but i also have 14" wheels). i max out @ 120-125 beacause of my ecm
http://www.fatboyraceworks.com/gears/
http://hondaswap.com/reference...29132/
