car push starts but doesn't start with key?
i have a 1992 civic hatchback with a ls swap and i can push start it but i it does not want to start with the key fuel pump primes everything good main relay good what could be the cause of this??? please heLP any input is appreciated thanks
Re: car push starts but doesn't start with key? (red ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red ej »</TD></TR><TR><TD CLASS="quote">i would say the starter, just a wild guess</TD></TR></TABLE>
x2 check the fuses also
Re: (chingpo05)
it has a brand new battery in it. ive checked the starter wires a million times. how do i bypass the clutch safety switch and what is that going to do for me?
Re: (civic j)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic j »</TD></TR><TR><TD CLASS="quote">possibly a chipped master key.~!</TD></TR></TABLE>
say what??
say what??
there is a thin black wire that connects to the starter with a spade type connecter, make sure this wire is securely connected, if it is not it will not start with the key, I had this same situation with a friends 97ex, it would push start but it would not start with the key, the wire had come of we re attached the wire and it started fine
gl
gl
Re: (egsleepercivic)
starter came off my buddys running gsr then took it too advance auto to see if it was any good and they said its good has to be something with the ignition bad or something. the guy i bought it from left it outside with no drivers side window for a few months could of the ignition got wet and something shorted out or something or that sort?
starter is off a 00 gsr that will work with a ls swap with b16 tranny correct?
Re: car push starts but doesn't start with key? (Timmyflys)
yes ignition/starter wire, i see this all the time after i had mines F'ed up. i rewired and starts fine.
Re: (civic j)
newer hondas have these but none of the 92-00 civics shoudl have them. i had the problem with the ls swap into my 99 civic. i had to run a ground wire to it and it has started fine ever since
Re: (kleanlscivic)
is there a ground anywhere on the starter? theres the black and white wire to the starter and then the positive cable on there is there suppose to be a ground or something on there?
Re: (Timmyflys)
its gotta be a bad ground. i had a loose bracket on my chassis to tranny ground and my car refused to start. but it would push start. CHECK ALL YOUR GROUNDS
Re: (electron_si)
just did the swap got a good valve cover ground tranny ground is good ground on the thermostat is good is there suppose to be one on the starter i don't know wat else it could b
