Was a sunroof an option on a 97 Civic LX???
I have a 1997 LX with a sunroof that I just got a couple of weeks ago.... based on the research I am doing, it looks as if the sunroof only came with the EX... so that would probably mean that I have an aftermarket roof...
Just curious!!!
Just curious!!!
H-T White Ops
According to the EPC, no.
I'd be interested to see both of these roofs. I have an EX coupe with a stock roof and it's very different in design than most aftermarket roofs.
EDIT:
Here are the pages in the EPC where the moonroof parts are listed. These are found under the '97 EX sedan listing, but are not found under the '97 LX sedan listing.
07 INTERIOR/BUMPER
-- 07 ROOF LINING
-- 2.5 LINING ASSY., ROOF (SUNROOF) - (*NH220L* (CLEAR GRAY)) ---- 83200-S01-A11ZA
-- 2.8 LINING ASSY., ROOF (SUNROOF) - (*YR98L* (COAST SAND)) ---- 83200-S01-A11ZB
07 INTERIOR/BUMPER
-- 08 SLIDING ROOF
---- (ALL PARTS)
---- 1 CLIP, OIL DRAIN ---- 15707-634-000
---- 2 CLIP, AIR HOSE (16) ---- 18534-634-670
---- 3 VALVE, FR. SLIDE ROOF DRAIN ---- 70052-SH3-000
---- 4 TUBE, RR.DRAIN VINYL (SUNROOF) ---- 70060-S04-000
---- 5 VALVE, RR. DRAIN (SUNROOF) ---- 70062-SH3-000
---- 6.2 SEAL, SUNROOF FRAME ---- 70080-SR4-003
---- 6.3 SEAL, SUNROOF FRAME ---- 70080-S01-A01
---- 7 RUBBER, FR. SUNSHADE STOPPER ---- 70095-SR4-003
---- 8.2 FRAME, SUNROOF ---- 70100-S04-003
---- 8.3 FRAME, SUNROOF ---- 70100-S01-A01
---- 9 GLASS ASSY., ROOF ---- 70200-S01-A01
---- 10.2 COVER, R. STAY ---- 70620-SR4-003
---- 10.3 COVER, R. STAY ---- 70620-S01-A01
---- 11.2 COVER, L. STAY ---- 70625-SR4-003
---- 11.3 COVER, L. STAY ---- 70625-S01-A01
---- 12.2 SUNSHADE ASSY., - (*NH220L* (CLEAR GRAY)) ---- 83210-S01-A01ZA
---- 12.5 SUNSHADE ASSY., - (*YR98L* (COAST SAND)) ---- 83210-S01-A01ZB
---- 13.3 HANDLE, SUNSHADE - (*NH220L* (CLEAR GRAY)) ---- 83213-SR4-003ZC
---- 13.6 HANDLE, SUNSHADE - (*YR98L* (COAST SAND)) ---- 83213-SR4-003ZD
---- 14.3 TRIM, SUNROOF - (*NH220L* (CLEAR GRAY)) ---- 83250-SR4-003ZB
---- 14.6 TRIM, SUNROOF - (YR98L* (COAST SAND)) ---- 83250-SR4-003ZD
---- 15 SCREW, TAPPING (4X10) ---- 90130-693-000
---- 16 CLIP, SLIDE ROOF DRAIN TUBE ---- 91504-SE3-920
---- 17 BOLT-WASHER (6X16) ---- 93405-06016-08
---- 18 SCREW, PAN (5X8) ---- 93500-05008-0G
---- 19 WASHER, PLAIN (5MM) ---- 94103-05700
---- 20 BULK HOSE, VINYL (10X14X3000) (10X14X1250) ---- 95003-33003-10M
07 INTERIOR/BUMPER
-- 09 ROOF SLIDE COMPONENTS
---- (ALL PARTS)
---- 1 CHANNEL ASSY., DRAIN ---- 70241-S04-003
---- 2 STOPPER, DRAIN CHANNEL ---- 70251-SP0-003
---- 3 RAIL ASSY., R. GUIDE ---- 70310-S04-003
---- 4 HOLDER ASSY., R. GUIDE RAIL ---- 70312-S04-003
---- 5 RAIL ASSY., L. GUIDE ---- 70315-S04-003
---- 6 HOLDER ASSY., L. GUIDE RAIL ---- 70317-S04-003
---- 7 STAY ASSY., R. ROOF GLASS ---- 70331-S04-003
---- 8 STAY ASSY., L. ROOF GLASS ---- 70336-S04-003
---- 9 CABLE ASSY., SUNROOF ---- 70400-S04-003
---- 10 MOTOR ASSY., SUNROOF ---- 70450-SR4-003
---- 11 BASE, R. DEFROSTER ---- 70532-S04-003
---- 12 BASE, L. DEFROSTER ---- 70537-S04-003
---- 13 COVER, R. RAIL ---- 70630-SR4-003
---- 14 COVER, L. RAIL ---- 70635-SR4-003
---- 15.3 SHIM, STAY (1MM) ---- 71997-692-920
---- 15.6 SHIM, STAY (2.0MM) ---- 71998-692-920
---- 16 SCREW, PAN (5X10) ---- 90110-SP0-003
---- 17 BOLT, SLOT (4X6) ---- 92301-04006-0A
---- 18 BOLT-WASHER (6X16) ---- 93401-06016-08
---- 19 SCRE, PAN (5X6) ---- 93500-05006-0G
---- 20 SCREW, TAPPING (4X8) ---- 93901-34120
---- 21 NUT, FLANGE (6MM) ---- 94050-06000
---- 22 NUT, FLANGE (6MM) ---- 94050-06070
---- 23 NUT-WASHER (6MM) ---- 94071-06080
---- 24 E-RING (4MM) ---- 94540-04029
08 BODY/AIR CONDITIONING
-- 06 OUTER PANEL
---- 8 PANEL, ROOF (SUNROOF) ---- 62100-S04-J20ZZ
Modified by NOFX at 9:44 PM 7/24/2007
EDIT:
07 INTERIOR/BUMPER
-- 07 ROOF LINING
07 INTERIOR/BUMPER
-- 08 SLIDING ROOF
---- (ALL PARTS)
07 INTERIOR/BUMPER
---- (ALL PARTS)
-- 06 OUTER PANEL
H-T White Ops
Re: (Hans Moleman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hans Moleman »</TD></TR><TR><TD CLASS="quote">I just thought the LX was a DX but with kinda like an HX, which is not EX. </TD></TR></TABLE>
What?
What?
Re: (punoy69)
WTF??? can someone say that **** like 5 times fast?
Re: (punoy69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by punoy69 »</TD></TR><TR><TD CLASS="quote">haha wtf</TD></TR></TABLE>
LOL you sig-ed it! LX is pretty close to an EX except for the engine being the main difference. LX is like a DX but not like a CX which is not a HX but is a GX which is not an SI and rare but is like EX (the SI). So they almost all end in X's. poop
H-T White Ops
Re: (sageuvagony)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sageuvagony »</TD></TR><TR><TD CLASS="quote">
LOL you sig-ed it! LX is pretty close to an EX except for the engine being the main difference. LX is like a DX but not like a CX which is not a HX but is a GX which is not an SI and rare but is like EX (the SI). So they almost all end in X's. poop</TD></TR></TABLE>
Your post doesn't make sense either.
An LX sedan is between a DX sedan and an EX sedan. A GX sedan is a factory modified LX sedan. A CX hatch is a DX hatch with fewer trimmings. An HX coupe is between an EX coupe and a DX coupe, and has a VTEC-E engine. And an Si coupe is basically a factory modified EX coupe.
Re: (NOFX)
I know it didn't make sense I just woke up after a LONG nap with MAJOR back pain (stupid futon.. memory foam mattres on the way!) and come to read such a mind boggling post.. ignore me owww my back!!!
H-T White Ops
Re: (Hans Moleman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hans Moleman »</TD></TR><TR><TD CLASS="quote">LOL!
Sorry for bringing it up again, but I was serious on what I said. </TD></TR></TABLE>
Well, I've made a full chart to show the differences in all the coupes and all the hatches. I'm working on the sedans and then I will make a thread listing all the differences between each trim. Then you can see it all compiled neatly and it might make better sense.
nightscream
11
07-12-2020 12:10 PM
2003, 70080s01a01, 70331s04003, 83210s01a01za, 83210s01a01zb, assy, civic, clear, drain, gray, honda, nh220l, odyssey, roof, rr, slide, sunroof, sunshade, tube, valve
