CEL code 15 Ignition output signal problem solved
Well I did alot of searching to find the problem to my code 15 Ignition output signal, but was unable to find a cause. I have a 1990 Honda CRX DX converted to OBD1 and MPFI. After doing a compression test I went to start my engine and it just cranked but no start. I was throwing a code 15. So I replaced my coil and ignitor with no luck. Dist had voltage and injectors were firing but no spark.
Long story short I discovered I had a bad connection in the yellow/green wire coming off the dizzy I repaired it and it fixed my problem. This is just my case and I thought I'd share since I wasn't able to find this cause in any other thread from searching. That is all..
-CHris
-CHris
