Help: Car has been bucking and shutting off
Sort of new to the forums, do not flame please.
The motor is a d16z6. Car starts up fine, however very few moments after idling fine, the car will buck a little (try to stay on) and just shut off, the speedometer is jumping and the rpm as well. This also happens after driving around, only difference is the car bogs out and completely shuts off and I'm stuck until i stop and turn it on again.
So far at idle, the car does not throw a cel, however it does come on when it starts dying.
Ive been told it could be my fuel pump or anything related.
Any ideas guys?
Any ideas guys?
first off try and catch that check engine light, it will give you atleast a direction to go.
or check your fuel filter or timing
Re: (DecentCivicZ6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DecentCivicZ6 »</TD></TR><TR><TD CLASS="quote">is this a swapped engine first off?</TD></TR></TABLE>
yes
and the CEL only comes on as the car shuts off does not blink or anything along with battery oil and just about every other light on the Gauge cluster, the car shows no cel at startup or when running
yes
Re: (MasterShake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MasterShake »</TD></TR><TR><TD CLASS="quote">next time its cutting off and the light cuts on, cut the car off then check the code.</TD></TR></TABLE>
Tried that
The light cuts on every time the car bogs and tries to stay alive,
when it normalizes, light goes away.
when it dies, light goes away, only thing blinking when checking for code is airbag
Tried that
Re: (MasterShake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MasterShake »</TD></TR><TR><TD CLASS="quote">have you checked the plugs? when was the last time you did some sort of tune up?</TD></TR></TABLE>
They are pretty old, someone else told it could be a vacuum leak somewhere, if the car is not throwing cel
B A N N E D
yeah, could be a vacuum, bt usually that makes them idle from high to low high to low high to low rpm. But yeah check the vacuum line at fuel regulator..make sure its gettin vacuum
yea its been both idling low to high, high back down to low, and idle to shut off, car does struggle to stay on.
any other ideas other than vacuum and plugs?
Re: (MasterShake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MasterShake »</TD></TR><TR><TD CLASS="quote">is it hard to start?</TD></TR></TABLE>
no starts right up
no starts right up
Car is still bucking, another symptom is every time it bucks the gauge cluster flashes, airbag, cel, seat belt, everything. It happens a lot in low idle, not so much between 2-4k rpm, and happens after 4k, but not as bad in low idle.
Car is still not throwing cel,
Check your main ground, I had that problem with my Civic once, when it would die the rpm, speedometer would jump around like crazy. Turned out to be the main ground, ecu getting no power then power making it go crazy.
susb16
10-12-2012 10:55 PM
jurenic
10-28-2008 01:14 PM
