header problem
Old Jul 12, 2007 | 10:18 AM
ekvtec's Avatar
Default header problem
just install a 4 2 1 headers on my single 99 ej and now my check engine light came on . i use the code readers to see what the problem it say low volt on o2 censor and too lean and also it said fuel trim malufunction i thing it the air and fuel mixture aint right can somebody help?
Old Jul 12, 2007 | 10:42 AM
quapouh's Avatar
Default Re: header problem (ekvtec)
well if you disconnect your secondary o2 sensor from the loop it wont give ECM proper readings and mess up the mixture and throw a code ... get yourself a o2 simulator for the secondaru o2 sensor
Old Jul 13, 2007 | 10:04 AM
ekvtec's Avatar
Default Re: header problem (quapouh)
if i dicconnect the 02 censor there will be an opening and where can i get that 02 stimulator?
Old Nov 27, 2007 | 02:27 PM
random chaos 85's Avatar
the computer doesnt use the secondary o2 to adjust fuel trim. all it does is make sure the cat is doin it job. just a lil fyi
skata89
Apr 3, 2008 12:26 PM
gemini05
Jun 18, 2006 03:25 AM
allmotorsi04
Nov 24, 2003 07:51 PM
kingmonkey
Oct 27, 2003 02:05 PM
ricky_gunns
Mar 25, 2003 06:42 PM
