Mushy Transmission Feel
So I was just driving around and I went to fifth gear and the shifter feel was really mushy I then checked all gears and they felt the same. It's not as precise or a nice feel anymore. I've noticed some leaking oil under right where the tranny is attached to the motor. I also have Polyurethane shifter bushings. Any ideas???
Re: Mushy Transmission Feel (excivicboy96)
Oil by where engine and tranny join. Your rear main seal most likely is going. And mushy meaning? like sloppy shifting? wigglyness? kinda hard to feel what u feel..
Modified by sageuvagony at 9:38 AM 7/14/2007
what is the condition of the bushings? Hows ur oil level? I notice I've been loosing a lil tranny oil and the shifter fele really changes as it's getting low
if you bought HONDA MTF from the dealer (2 quarts) you'll notice that when you shift, it'll feel like you're cutting butter with a hot knife... at least that's what mine felt like. Mine was the new formula. But if you dont want authentic stuff, 10w30 will do just fine.. jsut wont be as soft
Re: Mushy Transmission Feel (sageuvagony)
Alright so I put some 10w-30 oil in the tranny and it fixed the problem. Are there any seals i should check for leakage? I know It's leaking becuase I can see some on my garage floor every day.
Stouts 'n' Scotch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by excivicboy96 »</TD></TR><TR><TD CLASS="quote">Alright so I put some 10w-30 oil in the tranny and it fixed the problem. Are there any seals i should check for leakage? I know It's leaking becuase I can see some on my garage floor every day.</TD></TR></TABLE>
If it's coming from under the flywheel cover, it's most likely your mainshaft oil seal.
Otherwise, check out your axle seals.
B A N N E D
yep, gotta pull the tranny off to change it, its fun, lol, Very cheap seal, and very easy to change once you pull tranny off.
