Fluidyne Teg rad in 2000 civic si???
I'm wondering, the full radiator that Fluidyne makes for 94-01 Integra, does in bolt on in my 2000 Civic si if I have removed the A/C?
Thanks
Thanks
Re: Fluidyne Teg rad in 2000 civic si??? (psegs80)
Without modification to the brackets on the driver side where the a\c was before is what I'm trying to find out! Would prefer a full rad vs. a 1/2 rad!
Thanks
Thanks
Re: Fluidyne Teg rad in 2000 civic si??? (5_Lug_B)
I'm using a C&R Integra Radiator in my ITR swapped 96 Civic coupe. You will have to modify the driver side bracket. You'll have to remove the driver side bracket (drill out the spot welds) and screw it into the crossmember where it will need to be located. I'm pretty sure you'll have to remove the condenser brackets too. I had to make all new brackets for mine, but thats a whole other story.
Hoodwinked
05-27-2004 11:02 PM
battyx
12-09-2003 03:37 PM
SoloSol
10-25-2002 08:48 AM
