Y7 Intake question
Y7 Intake question
As we all know Y7 intake had to be different from all others and squat on the top of intake manifold. I was wondering if I could just swap intake manifold runners with throttle body and all sensors from Y8 to make TB facing to the side and get myself CAI ... I plan on leaving engine pretty much stock because I love fuel economy and just wondering if it's worth the effort and labor to swap intakes or should I just put high flow square filter [sumthing like K&N] in the box and call it a day? Are there any dry [not oiled] high flow filter that would fit the box?
Thanx for comments
Thanx for comments
B A N N E D
ive seen one with a stand up intake manifold, believe it was the Z6 manifold they used tho..wasnt that big fat Y8. But they said it made a NICE difference vs that stock manifold.
Re: (DecentCivicZ6)
I was rather thinking about side facing like Y8 and most of other honda intakes ... will Y8 fit on Y7 head ... and will it work as it supposed to?
B A N N E D
thats the same as Z6, looks exactly like the Y8...both sideways. same as D15b7. and ANY other intake manifold besides Y7.....might have to do some wiring for the Y8
Re: (DecentCivicZ6)
but the size and mounting points are the same? So when I get Y8 or z^ intake I can just swap it and it will fit to mate with y7 head? ... growl ....
Re: (quapouh)
Yes, the Y8 IM will swap directly with a Y7 IM. You will need a 96-98 AUTO Y8 IM, new IM gasket, and some hoses. Not sure how much power it will actually get you or whether a k&n is better/worse, but it does allow you to run a turbo without a lot of custom piping. All depends on what you want to do with your car.
Y7->Y8 IM discussions:
http://www.d-series.org/forums...33252
http://www.d-series.org/forums...=3185
Good luck!
Good luck!
I swaped it out on my y7... just make sure you use the y7 TB and injectors... also make sure when u get ur TB gasket get one for the y7 not y8... as for the power gains... next to none... for intake sound improvements 100% better!!
Re: (EKEJ6)
ok, so basically it will bolt up no problem, how about throttle cable location - can I reuse Y7 setup or do I have to go Y8 all the way .... any writeup you've seen around those parts?
Re: (DecentCivicZ6)
https://honda-tech.com/zerothread?id=1018993 it took like 5 seconds to find in the faq
well its the same but for a y7 and adds more power to ur top end.
the y8 manifold is like the TYPE R but for d sereis.
russian_racer
03-19-2003 11:06 PM
