I'm Tapping my oil pan and i have a quick question!
Ok so just to clarify, I should be tapping the pan in the middle of the deep end as high as i can right?
its for a y8
and then what size of fitting should i use....right now i have two fittings, a 90 degree with a 3/8 inch inlet and outlet (the fitting itself is like 3/4 of an inch but the actual hole is 3/8) and another fitting that is the same size but a 45 degree angle instead...do i need an even bigger size (cause i think i heard somewhere that i need a 1/2 minimum and that 5/8 is ideal...but that's friggin HUGE!)
....if you guys could post up some pics of your tapped oil pans i would be SOOOOO helpful!
Thanks guys
patrick
its for a y8
Thanks guys
patrick
rdeezy78
11-02-2009 06:45 PM
patrickd_21
07-13-2007 05:20 PM
BigMoneyP
05-29-2006 07:05 PM
