ENDLINKS WONT FIT ON MY FUNCTION 7 LCAs!!!
Hey guys..
I'm running the ITR 22mm rear sway bar reinforced w/ the ASR sub frame. I just picked up Function 7 LCAs (which i've been waiting over a month for) ..
Anyways, me and my buddy were putting them on. everything went good except for a broken bolt. We fixed that, and unfortunately came across another problem..
The endlink bolt that came w/ the ASR subframe and 22mm sway bar, which connected from the end link into one of the 3 holes of the F7 LCA did not fit, the bolt was too short and wouldn't allow the nut to screw on
I'm pretty sure i have to buy new endlinks.. My question is: Is there one that stands out from the rest?? i know it's not really a performance issue, too much. But I'm just looking for an end link that supplies a bolt long enough to fit through the f7 LCAs. Thanks a lot guys
Re: ENDLINKS WONT FIT ON MY FUNCTION 7 LCAs!!! (instructor74)
hmm intresting i am about to do the same setup here is a link from kingmotorsports that says the function 7 endlinks work perfect with thier lcas http://www.kingmotorsports.com...at=36 maybe try those. but please let me know how it turns out so i am not stuck in the same boat.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instructor74 »</TD></TR><TR><TD CLASS="quote">why not just get a longer bolt?</TD></TR></TABLE>
No ****...
If the length is the only thing holding you back, don't swap out the entire end link...
No ****...
Read this...
https://honda-tech.com/zerothread?id=2052268
Then I have some for sale here! They are brand new and cheap...
http://www.hondamarketplace.co...67243
There IS an allen wrench hole on the bottom of the bolt, but i tried to turn it and it just kept turning. So, i HEAR that f7 endlinks suck. And everyone says to go BLOX. which is what i'm leaning towards, but not so sure yet. The shop around here can get me f7 endlinks for $30. What's the difference if i go BLOX?? and is it really worth it??
JEM MotorSports
09-04-2006 02:48 AM
mixmastabob
01-06-2004 09:51 PM
