JDM no Vtec Pressure Switch?
Old 08-22-2007, 10:38 PM
xXSilentScreamXx's Avatar
Default JDM no Vtec Pressure Switch?
well some jdm motors dont have it
so im throwing a code for the switch *cel 22* and my oil pressure is good and i have a
jdm h22
if its not present on some motors then can i take mine off?
seems like its not needed?
Modified by xXSilentScreamXx at 12:11 PM 8/24/2007
Old 08-22-2007, 10:47 PM
smileycvc's Avatar
Default Re: JDM no Vtec Pressure Switch? (xXSilentScreamXx)
This happend with an H22 swap I helped do, to be honest I dont remember exactly how we did it, but I know its possible to somehow fix the cel.
Old 08-23-2007, 01:22 AM
BlueIntegraBoy's Avatar
Old 08-23-2007, 10:18 AM
smileycvc's Avatar
Default Re: JDM no Vtec Pressure Switch? (BlueIntegraBoy)
I knew there was a way.
Old 08-23-2007, 02:04 PM
Default Re: JDM no Vtec Pressure Switch? (smileycvc)
but see i have the switch
is it still ok to bypass it?
Old 08-23-2007, 05:09 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xXSilentScreamXx &raquo;</TD></TR><TR><TD CLASS="quote">but see i have the switch
is it still ok to bypass it?</TD></TR></TABLE>
You can. It's only there for a preventative measure to only engage VTEC if there's enough oil pressure.
Old 08-23-2007, 05:12 PM
RCautoworks's Avatar
If you have the switch, why not hook it up ? Am I understanding this correctly, you have it, but your throwing a code cause its not hooked up, and you want to get rid of it ?
Just hook it up.
Old 08-23-2007, 06:10 PM
Default Re: JDM no Vtec Pressure Switch? (RCautoworks)
its hooked up the swtich is good and my oil pressure is fine??
but it still throws the code ???
Old 08-23-2007, 06:52 PM
smileycvc's Avatar
then it sounds like you have some issues with the wiring somewhere.
Old 08-23-2007, 07:33 PM
SkankyEJ7's Avatar
have you bypassed the switch? my car doesnt have vtec pressure switch and it engages vtec flawlessly
Old 08-24-2007, 12:36 AM
Default Re: JDM no Vtec Pressure Switch? (SkankyEJ7)
so im guessing its unneeded
Old 08-24-2007, 10:15 AM
bump
waht happens if vtec engages and theres not enouff oil pressure?
Old 08-24-2007, 10:17 AM
Probot's Avatar
CEL light..car just immediately backs off (as if you slammed on the brakes, the whole car jolts)..and if you try to accelerate passed 5500 the car will do the same thing.
happened to me a week and half ago. just reset ECU by unplugging the battery and your on your way.
EDIT: not sure what CEL it is either cause it doesnt blink it just stays on...i reset the ECU, put 4 qts of oil and it didnt happen again.
Old 08-24-2007, 10:36 AM
Katman's Avatar
Hi.
First off code 4 is not related to the VTPS. Code 22 is.
Code 4 = CKP sensor (crank position sensor)
check it out here:
http://www.ff-squad.com/tech/ecu/mil-codes.jpg
The CKP sensor is in the dizzy. I suggest trying a different distributor.
Solster's Avatar
Default Re: JDM no Vtec Pressure Switch? (Probot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Probot &raquo;</TD></TR><TR><TD CLASS="quote">EDIT: not sure what CEL it is either cause it doesnt blink it just stays on...i reset the ECU, put 4 qts of oil and it didnt happen again.</TD></TR></TABLE>
Dude Check your Oil More offten and you might not need to put in 4 Qts of oil to get in back to full.
Old 08-24-2007, 11:12 AM
Default Re: (Katman)
i ment "4=for"
not cel 4
srry
fixd
Old 08-24-2007, 03:30 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xXSilentScreamXx &raquo;</TD></TR><TR><TD CLASS="quote">bump
waht happens if vtec engages and theres not enouff oil pressure? </TD></TR></TABLE>
Um, its a sign, your engine won't rev that high or engage vtec cause you have an issue. Don't half *** the job, hook the sensor up the correct way and make use of the sensor itself.
Spool This
09-30-2008 11:59 AM
valentine97
01-17-2008 03:02 PM
jdmsiR20
35
04-03-2005 01:32 AM
ProjectLudeSiR
06-11-2004 10:00 PM
ProjectLudeSiR
06-10-2004 11:27 AM
Quick Reply: JDM no Vtec Pressure Switch?
