need help with my hatch..
ok, i bought a cx '94 with a blown engine. i put in a b15b7, but still retained the original harness, etc.. it wont start, do i need to change the distributor? how do i go about? any help would be great.
Re: need help with my hatch.. (gsrhatch2356)
spark yes, fuel yes, comp yes. its like it wants to start but backfires once in a while.. is ther a difference with positioning of the 8valve dizzy and the 16valve dizzy?
yup, its all right, still wont. is there a difference in distributors for the 8v and 16v d15b's?? i read somewhere about interchangable 1's.. is this one of them? i put my d15b8 dizzy on the d15b7. where can i find the part#?
Re: (enzopastor)
Your dizzy should be fine, i've swapped obd I's II's and ones from the 8 valve, and vtec so on and so forth. You are 100 percent that the plug wires are good? and timing belt. It should start regardless of where you have the dizzy lined up, but you can just throw it in the middle.
Re: (coneheadsracing)
yes i did this swap in my buddys car same exect one and it wouldnt start it was because we had the wires on the dizzy wrong, make sure your firing order is correct or else even if it does start it will run like a subaru
the rotor wont match when the engine is at top dead. all the bolts dont even line up. i opened the dist cap. the part number in the distributor is td-41u. why is this so?
Re: need help with my hatch.. (enzopastor)
if you got the motor right out of another car the timing shouldnt be off... i had the same problems and the majority of the time it was the order the spark plug wires were connected to the dizzy...
hondaciviceg4dr
30
03-29-2015 03:00 PM
gsrpedro
12-05-2008 11:42 AM
ilovejdmhoes23
01-18-2007 11:30 PM
TheAntiEndz0r
10
08-26-2003 07:15 AM
