Where is the oil pressure sensor for d16?
Re: Where is the oil pressure sensor for d16? (SoHc Ej1)
back of block, near oil filter, rubber boot over it
if you dont work out alot )if your arms arent buff as expletive) you can snake your arms up to where it is a remove it
i have that snap on adustable socket wrench that can turn or fold into its self and a nice deep socket will get it
otherwise use a racheting box end to get it with ease
Modified by 951kseries at 5:44 PM 8/22/2007
should be the only thing going into the block above the oil fiter. it may be just off to one side... but still above it. it's got a single wire going to it.
a 15/16 deep socket works, take it out and install a tee fitting put gauge sensor or line on side of tee and the stock pressure sensor on the other end
