Shifting is mushy??
Old 08-21-2007, 01:15 PM
xXSilentScreamXx's Avatar
Default Shifting is mushy??
when shifting into 1st 3rd and 5th gears, it feels mushy. once it's in gear, it also goes a little past where it's supposed to. for normal driving it go's into gear but as soon as i try to "speed shift" i get nothing. ill put it into gear wait a sec and still at high rpm's it acts up? possibly low on tranny fluid?
Old 08-21-2007, 03:00 PM
Default Re: Shifting is mushy?? (xXSilentScreamXx)
bump
Old 08-21-2007, 03:02 PM
97Ej6mike's Avatar
shifter bushing(s), and/or Clutch is starting to go if you are having trouble getting in/out of gears. Could you elaborate more on what symptoms you are having?
Old 08-21-2007, 03:38 PM
91hybridDX's Avatar
like mike said could be clutch, flywheel, shift bushings, or worst case scenario . . . the beginings of synchros going out.
Old 08-21-2007, 03:46 PM
instrument's Avatar
h22 cable tranny?
Old 08-21-2007, 08:34 PM
Default Re: (instrument)
yes and the clutch grabs like a mother its a stage 3 competition clutch
cruzing around the gears go in fine but its when i try to shift a high rpms is when it does this .....wahhhhhhhhhhh *clutch-gear then 1sec then release clutch* then wiiiiinnngggg
and then shifting feels mushy like it doesn't engage but it is engaged
Old 08-21-2007, 08:38 PM
gsr x civic's Avatar
try draining ur trans fluid and getting high performance ****.
Old 08-21-2007, 08:41 PM
Syndacate's Avatar
Default Re: (gsr x civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr x civic &raquo;</TD></TR><TR><TD CLASS="quote">try draining ur trans fluid and getting high performance ****. </TD></TR></TABLE>
That won't do anything.
@ OP:
It's probably your shifter linkage bushings. Not just the ones at the bottom of the shifter (although that's possible) but the ones where it meats the trans as well.
Mine was bad at the trans - replaced it last night w/ the one from the new trans (they torched the linkages off).
Old 08-21-2007, 08:51 PM
Default Re: (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">
That won't do anything.</TD></TR></TABLE>
well. in my friend's ep3, he had a third gear grinding problem (the a3 trans is notorious for this) so we got honda mtf and gm synchromesh and flushed out the old and put the mtf and like 1/6 synchromesh and it fixed it. i can't remember exactly how much synchromesh we put but it wasn't too much.
but hey, just trying to help
Old 08-21-2007, 08:58 PM
Syndacate's Avatar
but hey, just trying to help </TD></TR></TABLE>
I know, I've heard all the orgasmic flies about GM Syncromesh and Honda MTF.
"My tranny was grinding and the magnet filled up and a piece of 3rd gear fell out when I drained the fluid, and the input shaft bearing rolled out, and the throwout bearing FELL out.
I filled that thing up with Honda MTF and it's smooth as a baby's ***!!
Yea, I've heard it all before.
If you're grinding, you're grinding, the only thing Honda MTF is gonna do is provide you with the exact amount of lubrication so you can hide the grinding before something decides to take a crap inside your transmission and you're -1 gear.
Old 08-21-2007, 09:00 PM
If you're grinding, you're grinding, the only thing Honda MTF is gonna do is provide you with the exact amount of lubrication so you can hide the grinding before something decides to take a crap inside your transmission and you're -1 gear.</TD></TR></TABLE>
yes .. yess . .
but you don't gotta rub it in my face
for a resolution!
Old 08-21-2007, 11:06 PM
@ OP:
Mine was bad at the trans - replaced it last night w/ the one from the new trans (they torched the linkages off).</TD></TR></TABLE>
how will i know if they are bad and if so what causes them to go out??
the tranny only has 30k on it
o and junkyard or oem??
Old 08-21-2007, 11:45 PM
Default Re: (xXSilentScreamXx)
bump
Old 08-22-2007, 01:55 PM
are there bushings for lude shifters? all the shifter bushings i c are for linkage shifters? *teg a civic stuff*
Old 08-22-2007, 02:21 PM
97Ej6mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xXSilentScreamXx &raquo;</TD></TR><TR><TD CLASS="quote">are there bushings for lude shifters? all the shifter bushings i c are for linkage shifters? *teg a civic stuff*</TD></TR></TABLE>
There are different style/shpaed bushings (as far as i know) between hydrolic and cable run shifters. Since you have the H22, If and When you go to order aftermarket bushings (such as enery suspension, ect), order them for the prelude.
Eddie99
Honda S2000
24
10-16-2007 01:22 PM
suken19
03-21-2006 10:00 AM
VtecDA9
07-16-2003 05:47 AM
Jesse H
08-20-2002 05:04 PM
JustChou
04-18-2002 07:40 AM
Quick Reply: Shifting is mushy??
