How many quarts of motor oil for B16A 2nd gen
Re: (drtysohc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drtysohc »</TD></TR><TR><TD CLASS="quote">check it?</TD></TR></TABLE>
i cant really tell from the oil dip stick cause i am not sure if thats original one that comes with the engine or
Re: (crazyguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyguy »</TD></TR><TR><TD CLASS="quote">
i cant really tell from the oil dip stick cause i am not sure if thats original one that comes with the engine or </TD></TR></TABLE>
Is there any oil line/residue marked on your dipstick when you remove it? Remember new oil is yellow and can sometimes be hard to distinguish on the dipstick if you dont look at it closely.
Re: (Tonymoto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tonymoto »</TD></TR><TR><TD CLASS="quote">whenits between the 2 dots</TD></TR></TABLE>
No the highest dot is reccomended height read your manual...
Re: (soundpsych)
remember wen you do the oil change pour the oil in and turn your car on, let idle for half a minute, check dipstick again then adjust and try to fill it but dont overdue it cause that causes problems too
Re: (soundpsych)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soundpsych »</TD></TR><TR><TD CLASS="quote">
No the highest dot is reccomended height read your manual...</TD></TR></TABLE>
True, but the second dot is "1 qt low" - so it's not like you're really lacking in oil or anything.
In the upper 75% of the range of the two dots to the top dot is fine.
Re: (ejprimo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ejprimo »</TD></TR><TR><TD CLASS="quote">i always put 4.2 quarts into my b16a.</TD></TR></TABLE>
Stouts 'n' Scotch
Re: (ejprimo)
It's usually around 4 1/4 for me as well.
Re: (wiZCo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo »</TD></TR><TR><TD CLASS="quote">
It's usually around 4 1/4 for me as well.</TD></TR></TABLE>
same here.
same here.
invisible
21
12-27-2006 08:27 AM
Civicse
24
09-12-2005 08:46 AM
