MINI-ME OR D16Y8??
MINI-ME OR D16Y8??
MY QUESTION IS WHICH ONE IS BETTER AS FAR AS COMPRESSION OR TO RUN A TURBO OR ALL-MOTOR. FROM WHAT I HAVE READ THEY ARE BASICALY THE SAME BUT I WONDER IF IT IS JUST CHEAPER OR BETTER TO SWAP IN A D16Y8 IN STEAD OF THE MINI-ME SET UP?
THANX
THANX
Re: MINI-ME OR D16Y8?? (93dagsr)
If you can find one, Y8, why not just drop in that motor? It would already be put together and you'll probably get the same amount of power anyways. They are still both just D series.
Ek Forever y0!
Re: (91hybridDX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91hybridDX »</TD></TR><TR><TD CLASS="quote">I would say it depends on what route you want to go and what you feel is most worth your time and money.</TD></TR></TABLE>
mini me or d16y8? mini me
its a little more ideal to put a d16y8 head due to the slight displacement on a 1.5 non vtec block because it raises the compression to a cool 12.01 which that my friend is pretty damb close to a b16 compression ratio..that is the mini me
JDMGANGSTA
JDMGANGSTA
Re: mini me or d16y8? mini me (joezjdm4dr)
first he should clarify which non vtec block it is because a y7 is a 1.6 not 1.5 and unless the y8 has more quench area i really dont see how that head would raise the compression to a cool 12:1 without machining.
i would say screw all motor and turbo whatever engine you already have put together.
budget turbo FTW.
budget turbo FTW.
Ek Forever y0!
Re: mini me or d16y8? mini me (4drgsr96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joezjdm4dr »</TD></TR><TR><TD CLASS="quote">its a little more ideal to put a d16y8 head due to the slight displacement on a 1.5 non vtec block because it raises the compression to a cool 12.01 which that my friend is pretty damb close to a b16 compression ratio..that is the mini me
JDMGANGSTA </TD></TR></TABLE>
12.01:1 compression with stock components? What are you smoking? I want some.
awdriscol4
28
03-05-2005 10:13 PM
