bottom alternator bolt......
ok so i took the nut off of the bottom alternator bolt....and been hittin it with a sledge hammer......****** wont move....its not threaded or nethin......any suggestions? cant seem to get it
Re: bottom alternator bolt...... (TooManyTickets)
yea the top two bolts are off along with that bracket, the plug is dissconnected and so is the ground
yea i can pry it back an forth with a prybar.....doesnt exactly move freely.....sprayed some pb blaster on it.....bringin it to a friends tomorrrow to torch the sucker off
Re: (2ndGenREX)
yeah you should be able to move it by hand.
does the alternator have a removeable mount like on the d16? if so u may be able to remove it with the mount still attached and then let you other tools do the talking
Re: (TooManyTickets)
Did you ever get that bolt free. I have been having the same exactly problem with my 1998 Civic EX.
I have heated, pb blaster, heated, pb blaster then sledged the **** out of it like every day for the past 5 days. I have not given up yet. But the bolt is not moving at all. I can pry the alternator back and forth on the pivot bolt with a pry bar and a hammer, this blows!
Hopefully you got yours off and can tell me what you did !!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TooManyTickets »</TD></TR><TR><TD CLASS="quote">yeah you should be able to move it by hand.
does the alternator have a removeable mount like on the d16? if so u may be able to remove it with the mount still attached and then let you other tools do the talking</TD></TR></TABLE>
The Alternator does have a that removable mount, it is held on by two 14mm bolts. One can be accessed easily, the other is blocked by the alternator itself.
supraken
04-24-2007 11:32 AM
dpkelly
01-01-2006 12:54 PM
ShakesTheKlown
06-12-2004 02:24 PM
