extremely frustrated ... vibration in steering wheel with proper alignment and wheels balanced
i posted this is the suspension forum but still havent had any luck
ok well here the story i have a 98 ex coupe. took a b series swap i had in my 98 hatch and put it in the coupe and at the same time swapped out the suspension with an extra set of koni yellows and tein springs i had in the garage. i have had this vibration in the steering wheel at speeds between 60-75. have had 2 seperate sets of rims and tire on it that are both properly balanced, i have rechecked the axel bolts numerous times, and the car has been to 3 placed to have the alignment verified. tie rods, ball joint, ect all look good. no one in my area is confident dealing with modified cars .... (this last place told me the motor was not in the engine bay straight.... this should give you an idea of the lack of competent people around here).
anyone have any ideas
Re: extremely frustrated ... vibration in steering wheel with proper alignment and wheels balanced (
hmm i have this same exact problem...
place i went to told me my caster on the front right was off
when i look at it it looks clocked at 11 and 5 where as my driver side is at 12 and 6
i dunno if thats your problem but (not to hijack a thread) does anyone know what to do about this?
just took the wheel of to triple check all suspension bolts were tight .... put the wheel back one and now im noticing low speed shakes when cruising even at 30-35
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bleedblue94 »</TD></TR><TR><TD CLASS="quote">just took the wheel of to triple check all suspension bolts were tight .... put the wheel back one and now im noticing low speed shakes when cruising even at 30-35 </TD></TR></TABLE>
for someone to tell you the motor isn't sitting straight, i'm going to take it you didn't do the swap yourself.
have you checked you motor mounts? they will cause vibration if cracked or torn. that will also expain why the motor isn't sitting straight.
double check your mounts are on right...then i would make sure your tire pressure is the same on each wheel. I had 3 tires with 28 psi and 1 with 19 psi and i had vibration from 70mph and above
i took the swap right out of my hatch and put it in the coupe ..... both 98s ...yes i did it myself as i have doen ten or so other swaps without issues .... mounts all have poly inserts in them. everything was simply tranfered from the hatch to the coupe.
the garage that said the motor wasnt in straight was inspecting the alignment....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bleedblue94 »</TD></TR><TR><TD CLASS="quote">vibration in steering wheel with proper alignment and wheels balanced</TD></TR></TABLE>
Got the same problem. I installed a set of used tire last weekend and got the guy to put the camber worn side on the outside. Everything is properly balanced and I get vibration.
My only explanation is uneven tire wear since I notice there is less vibration as I drive(wear down the tires)
thats not the problem ... i have a set of camber worn tires on sl;ips and a set of new cooper tires on heliums and it does this with both sets
btw i just had all 8 front studs changed out as well in case there was a bent stud... took the wheels off today to triple check the suspesion bolts were all tight and now im noticing a vibration 30-35 .... im gonna go insane
i had the same problem...i got new axles...problem solved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mikes2000civicsi »</TD></TR><TR><TD CLASS="quote">i had the same problem...i got new axles...problem solved</TD></TR></TABLE>hmmm you know thats the direction im leaning at this point
if you're using aftermarket wheels, do they have hubcentric rings?
Here are a few things to check. 1st you said the tie rods, and ball joints look okay. Did you actually test them for play? I chased a problem for 5 or 6 months and 6 alignment shops missed a bad lower ball joint. Kept telling me it was a bad brake rotor or caliper hanging up. 2nd Make sure that the brake rotors are not warped and calipers aren't hanging up. 3rd jack the car up take off the wheels off. Have a friend start the car put it in gear and turn the wheel back and forth look at the drive shafts see if they are shaking, binding, or making noise.
well i had that problem im my eg before. it turned out that my rim was bent due to when i got a flat in this construction zone. i bought a whole new set of nippon spoon rims. the right is smooth now. my 93 gsr which i had before my eg had that problem too. this was do to the front hub bearing.
try a whole new set of rims. i noticed you said you had two sets. but yeah, check your hub bearings, shake the disc brakes and see if they move. if they're loose your in for some new ones. good luck.
oh i balanced my rims and tires on my eg like 10 freaken times. never went away till i bought a new set of rims.
yeah thanks ... ive tried both sets of wheels numerous time and had them rebalanced and checked ....
already tried shaking the wheel assemblied and nothing moved .... everything is solid .... im gonna make phone calls tomorrow looking for a decent price on some oem axles
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bleedblue94 »</TD></TR><TR><TD CLASS="quote">yeah thanks ... ive tried both sets of wheels numerous time and had them rebalanced and checked ....
already tried shaking the wheel assemblied and nothing moved .... everything is solid .... im gonna make phone calls tomorrow looking for a decent price on some oem axles</TD></TR></TABLE>
but if the wheels you tried don't have hubcentric rings, your wheels may not be perfectly centered on the hub, which can cause vibrations at high speeds.
I had a sligtly bent axel.... I found out when i was chasing a noise under the car and had it on stand. I had my girl friend sit in it and put it in drive then I grabbed the axel lightly and let it spin in my grip.... have some one start pushing the gas and you should feel if the axel is bent or not... It worked for me so GL
i understand that, but the issue is now noticable present at lower speeds as well and at acceleraton which are signs of inner joints going out .... i have a set of oem wheels on one of my cars and i will try hose out to ... but im almost certain its an axle issue at this point
when u really get on it...in the upper rpms it should vibrate alot..if it does then axles.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mikes2000civicsi »</TD></TR><TR><TD CLASS="quote">when u really get on it...in the upper rpms it should vibrate alot..if it does then axles.</TD></TR></TABLE>hey i sent you an im on aim
audsyn
07-30-2009 02:57 PM
kaluwa3
06-06-2008 08:31 PM
bleedblue94
Suspension & Brakes
33
03-25-2008 08:11 AM
