dose this look right?
Re: dose this look right? (.:Swig:.)
o hay i hit the switchs all day long
its a trip it just bumps up and down it has a new clutch and trans (jdm trans) when i try to drive slow it happens but when i take off fast its fine
well not that much better lol
Re: dose this look right? (eg1993lpc)
Hondas tend to jump on/off power at low RPM when you need to change ur plugs, wires, dizzy rotor, and cap...but somehow I don't think that's the problem here...
Re: dose this look right? (Syndacate)
lol what do you mean not the problem here? i just had my dizzy rotor, and cap changed 2 day ago but i have had the car 3 years now and its been the way sence day one
Re: dose this look right? (thenewguy93eg)
my car does the same thing but i put a clutchmaster fx300 which is there stage 3 clutch i believe, as well as a 9lbs flywheel. i was told that it was the lightened flywheel and then i was also told it could be the motor mounts or a combo of two since the motor is trying to keep up with the lightened restrictions causing the stock mounts to take alot more stress. im in the lookout for some hasport to see if it fixes it. goodluck on your findings.
1 Post
Re: dose this look right? (lpc805EG)
this happened to me once after a cluch job.
check your bolts taht connect you tranny to your motor. there should be no gap between both. i had a gap the bolts were coming loose. for not having the right tools.
Re: dose this look right? (Dead CIVIC)
Check your other motor mounts, upper mounts rarely go bad unless the the front ones tear and you don't replace them then the uppers tear also.
tallguy21
03-20-2014 05:36 PM
