question TDC and Comp Cams #59300 timing issues
Old 11-15-2007, 09:42 AM
labtec2's Avatar
Default question TDC and Comp Cams #59300 timing issues
i have a d16z6 motor that im basicaly done building, i was trying to set the inital timing so. i set the # 1 cylinder to TDC (4-3-2-1) and that went fine. when i put the camshaft in the head and had the hash marks (on the cam gear) where they were supposed to be (aftermarket OBX cam gear, its adjuatable thats about the only difference. same size & tooth count). so the cam is at zero and the #1 cylinder is at TDC. and when i tried to put the distributor in (after lining up the inside of the distributor cap so it faced the #1) the part that meets with the cam from the dizzy itself and the end of the cam did not line up.
ive followed the instructions to the letter in my HAYNES/HELMS but i think im still missing something....????
-line up motor to TDC #1 cylinder
-line up camshaft/cam gear to that they read 0 (0 being the number at the top of the cam gear degrees)
-line up dizzy so that its facing the #1 cylinder on the plug wires
and thats that???? right?
89ED
18
06-22-2018 03:38 AM
koulyoo
08-11-2010 06:05 AM
sbk23
06-19-2010 04:41 PM
jdm27ef
05-29-2009 02:52 PM
labtec2
11-15-2007 10:01 AM
Quick Reply: question TDC and Comp Cams #59300 timing issues
