gsr sputtering..help!!!
i have a 95 gsr swap in my 94 hatch..i swapped it in no problems..but sometimes when i would get on it the spark plug wires would pop out of the distributor cap...after that one day it started sputttering at low rpms once i pass 3k it goes away if i let it idle slowly it will shut off somtimes..already replaced spark plugs and wires ..and the cap/rotor..running out of ideas..
Re: gsr sputtering..help!!! (94eh2)
umm when did this start happening did you spinn your tires out or over ev it or down shift at really high rpm...and if you think it might be a skipped tooth then just get a new belt and reset you time acorrding to your manual!
