Radio issue
Radio issue
Hey i was wondering if anyone can point me to the right direction.. I kno thers a search above but it didnt help so much.. i am runnin a 99civic coupe. I got into a accident last night, and when da impact occured my whole headunit steroeo went inside.. i needa take out da panels.. are there any DIYs out there? i am still preti new to the scene.. thankz
Re: Radio issue (Ibazndude)
first you have to take out the panel under the radio where the 12v plug input is at. after you do that there should be two 8mm screws under the radio but since you have an aftermarket radio in there i think all you have to do is pry out the whole black dash piece that holds your radio and has your climate controls.......
Re: Radio issue (SaLvAcIvIc97)
Too get the audio units out you need to take out two screws in the glove compartment, 3 screws in the cruise control/under the steering wheel/bottom panel and then more screws to get rid of the middle piece holding the 12v plug. After that you will see the audio unit and you can pull what you need out of it.
Re: Radio issue (djessenz)
thankz alot, yeah i got it done sorry for da late post jus took off glove comparment pushed it back up, guna screw it in later
