cluster lighting
cluster lighting
ok so i changed the bulbs in my cluster and for some reason the temperature has no light.... so i take the cluster back out and look behind the temperature guage and theres no socket at all to put a bulb in.... but the tricky thing is, is that when the stock bulbs were in the temperature gauge lights up..... the car is a 00 lx and its the stock cluster heres a pic as u can see the fuel and temperature guages barely even light up... but theres no sockets to put bulbs in behind them somebody help i want them lit
Re: cluster lighting (Midori Green)
did you switch and flipped the terminals? are these LED lights? LEDS are diodes so they have one way flow of electricity.
Re: cluster lighting (LowTEC-Derbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LowTEC-Derbo »</TD></TR><TR><TD CLASS="quote">did you switch and flipped the terminals? are these LED lights? LEDS are diodes so they have one way flow of electricity. </TD></TR></TABLE>
what are the terminals??? are they the plugs?? thats possible and no these are not LED lights
Make sure the bulb that is near those two gauges works, also make sure you turned it all the way till it wont turn anymore.
Re: cluster lighting (ejoner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ejoner »</TD></TR><TR><TD CLASS="quote">Make sure the bulb that is near those two gauges works, also make sure you turned it all the way till it wont turn anymore.</TD></TR></TABLE>
thanks will do
thanks will do
miguey310
50
01-23-2010 07:33 PM
remove account
03-28-2005 05:18 PM
