dx harness on a cx shell
picked up a dx harness for my cx, but the harness does not have the map sensor plug. any one know what wire i need to splice to make this sucka work?
Re: (da_dude)
negative, dx chassis have a firewall mounted map sensor, as oppose to the cx which has the map sensor mounted on the top of the throttle body
OKay, are we talking about the 92-95 civic or the 96+ civic? Last time I check the dx harness is the same as the ex harness minus the vtec wiring. This was the 92-95 civic though.
Re: (Chewy Built !)
it should all be on the engine harness...it isn't separate...maybe you mixed it up and just got lost in teh wiring somewhere...double check
Re: (Chewy Built !)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chewy Built ! »</TD></TR><TR><TD CLASS="quote">negative, dx chassis have a firewall mounted map sensor, as oppose to the cx which has the map sensor mounted on the top of the throttle body</TD></TR></TABLE>
you are a retard, i have a dx hatchback and its on the harness
bluebird
05-25-2007 08:13 PM
SOHC_Brian
12-05-2003 09:07 AM
