obd1 d15 into obd2 ek dx , dizzy question and other
ok i know u can use the same egnineharness , now for the distributor , can u use the obd2 on on the obd1 motor? wat do u have to wire up for it to work? can i swap the oil pump and all the crap with sensors on it from the d16 non vtec to a d15 non vtec??
Re: obd1 d15 into obd2 ek dx , dizzy question and other (preludeboybmw)
I think the bolt patterns are different. What i would do if thats the case is swap internals of the dist. Much easier then repinning everything. Oil pump you could swap and everything else as well.
redracer1024
08-15-2007 01:39 PM
ID_ten_T
12-21-2003 10:35 AM
