car runnin on 3 cylinders just finished changing injectors HELP PLEASE
ok well jus finished installin rc 440s go to turn on car...it turns on but idles weird i hit the gas and it wont let me pass 3500 rpms so i check the injector clips all good.....car was runnin good with stock injectors so i put them back on same problem and i have a #16 cel (fuel injection) so i turn on da car again remove clip from #1 cylinder and nothin changes all other cylinder react when i remove the clips.....so i check the wiring from the injector everythin looks good......dunno wat to do please help
Re: car runnin on 3 cylinders just finished changing injectors HELP PLEASE (jdmek2277)
check voltage at the clip...then see if its actually spraying... they can go bad u know.
Re: car runnin on 3 cylinders just finished changing injectors HELP PLEASE (saikouEF8)
the car is getting spark and the plug is in the right spot also the injector is good already switched to another cylinder but same problem i have run out of tests to do......
creepy116
11-21-2008 10:46 PM
OrangeBoost
05-30-2006 10:22 AM
