spedo not working then freaking out????????
i have a 94 vx with a b18b gsr trans the speedo will not work at all. Then it will jump all over the place then go back to 0
Re: (b18 hatch mike)
this happened to me and it just ended up being the plug going into the vss. So if you have washed your engine recently or ever for that matter i would check the plug first before buying a new vss. Because if that is the case the vss plug is probably just in need of a cleaning.
If that vss cleaning doesn't help, then it could very well be a dizzy ignitor or coil issue. My tach use to go crazy at random times, then got a "new" reman dizzy and that fixed it...until this past month, now it's doing it again. Burned through a good dizzy in a year's time. ARGH!
Re: spedo not working then freaking out???????? (b18 hatch mike)
It may be a broken pin in VSSs plug, it also may be your cluster and VSS itself as well, not mentioning rusty electricity, in my case it was cluster that was f-u
Re: spedo not working then freaking out???????? (plakon83)
worked fine all day then backing into my garage tonight and it was like o-100-50-75-0
idk i will take a look at it this Sunday if i don't get a chance tomorrow
this happened the other day to our integra we're building it turned out to be a transmission ground strap small problem
