Wire tuck O2 Sensor code
I just finished my passenger side wire tuck and had to extend all 6 wires in the harness clip. Now I am throwing an Autozone code P0131, which says it is a Primary Heated Oxygen Sensor (Primary HO2S) (Sensor 1) Circuit Low Voltage code.
Re: Wire tuck O2 Sensor code (candyman206)
Did you extend them properly with solder and heatshrink? Have you double checked your work? Have you compared you work to a wiring diagram.
Re: Wire tuck O2 Sensor code (SkankyEJ7)
I don't have a wiring diagram. But I use solder and heatshrink. Is the O2 sensor even related to the harness I just tucked?
You could have effected one part of the harnesses attached to the O2 sensor, that specific harness usually runs infront of the trans.
yeah i used the same size wire, i relocated the engine compartment fuse box to the trunk and i do think that that is what has caused my problem. im trying to find a new harness to try to eliminate possibilitys.
