fuel pump help plz
fuel pump help plz
okay i was going to buy a new fuel pump because mine wont read the gas level.. but now im stuck with two fuel pump questions... wich fuel pump should i use a integra or a civic because my 94 civic has a integra ls motor....and wich one a 255 or a 195 im trying to be save a little fuel but still be able to do a ls/vtec...please help me
Re: fuel pump help plz (xiongtoua1990)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xiongtoua1990 »</TD></TR><TR><TD CLASS="quote">okay i was going to buy a new fuel pump because mine wont read the gas level.. but now im stuck with two fuel pump questions... wich fuel pump should i use a integra or a civic because my 94 civic has a integra ls motor....and wich one a 255 or a 195 im trying to be save a little fuel but still be able to do a ls/vtec...please help me</TD></TR></TABLE>
Um i may be wrong but doesn't the sending unit read the fuel level? The pump does just that and only that, pump.
I'm not completely positive, but I don't think the fuel pump has anything to do with your fuel level reading. I believe there is a seperate pickup/sensor for that. And for a mild swap with just bolt ons, a walbro 190 should be sufficient. buy that one that fits your car (although civic/teg should be the same).
Re: fuel pump help plz (reaction360)
that what i thought too but then when i was trying to look for a fuel sender on ebay couldnt find one so i thought the fuel pump and sender is probally together????
but still is it really sepreate from the pump???? and which one is it because when i open my fuel area up i see two plugs
Yes, the sending unit is next to or near by the pump...but preform two different functions. There are aftermarket units/sending units by Autometer, but not 100% sure they're available for Hondas or not. Might just try a junk yard unit...
Re: (blk92_d16)
nah i check out with a guy with a civic and he told me that the 94 civics and older ran on a floater and maybe my floater is stuck or either there is a wire shortage but i dont know??? he also said they are on on assembly that probaly explaine why the pump is on a assembly...
Re: (xiongtoua1990)
They are under your back seat beneath a metal cover held in by several screws.
There should be one hole for the level unit, and one for the fuel pump. And they both have there own wires connected to them.
Good Luck!
Good Luck!
Re: (Budget Racer)
if you order anything to replace it, just ask for a fuel pump assembly. it will come with everything you need (generally minus the sock)
djakob
11-06-2012 01:31 PM
