squeak???
squeak??? is there a mouse in my engine bay??
Well all my belts including timing belt had been change like couple months ago.
But I have this squeaking sound when only I bring up the rpm it get louder.
It goes squeak pause squeak pause and me wtf ?
When I turn the ac on the squeaking sound isn't that loud but you barely could here it.
Could it be my ac compressor going out soon?
possibly a/c or another pulley bearing. check belt tension and p/s fluid. you could also spray wd-40 or belt dressing on the belts to see if it stops then you would have it narrowed down to a belt and not a water pump cuz those are pretty sqeaky when they start to go.
Re: (cherroneballs)
OH I FORGOT THAT MY WATER PUMP WAS CHANGE AT THE SAME TIME WHEN THE BELT WAS CHANGE ALSO.
THE A/C BLOW PRETTY COLD SO IM NOT SURE IS IT GOING OUT OR NOT.
Modified by immajackuup at 2:06 PM 4/4/2008
when i drive in second gear i hear this growling sound sometime too.
Modified by immajackuup at 2:24 PM 4/4/2008
CandyMamaRy
01-25-2011 02:38 PM
IP RACING
18
09-26-2008 10:15 PM
