Climate Control Question
Hey everyone,
So, this morning I went into work and everything was fine with the car. I came back out 10 hours later and got in, started up just fine, and all that jazz. Only thing is, neither my heat, nor A/C work on the climate control settings 1 or 2. However, when I set it to 3 and 4, the heat and A/C work just fine.
I drive a 92 sedan. Could this be the climate control unit itself? Or is it more likely the blower motor or blower motor relay?
Re: Climate Control Question
I just finished replacing the blower motor since it was squealing anyways, no difference. Going to check the blower motor relay next.
I would check the relay myself. I know in a lot of other cars the switch or blower's setting resistors can blow, causing this. I'm not 100% on the layout of our Civics though
Hello! I have a similar problem in a 92 DX. At first the 1 and 2 speeds weren't working, only 3 and 4 worked. That lasted for about a year and now 3 and 4 are not working also. Sometimes they do turn on, but rarely...
I took the switch out of the dash and tested it with multimeter. It does have connections on all of the speeds. But I don't know what to test next.
Could it also be a resistor? Even if the 4th speed is not working? Where is that resistor located?
https://honda-tech.com/forums/tech-misc-15/blower-motors-works-speeds-3-4-but-not-1-2-fix-how-2082345/
Thanks!
I found the problem! It was actually the plug that connects to the blower motor. Every time I would move it, the blower would go on and off. I used a screwdriver to squeeze the pins closer, so now it works just fine (on 3rd and 4th). Now next thing is to replace the resistors
