Need help with 00 Si seats!!!!!!!!!!!
I'm in the middle of swapping out my Del sol seats for a mint set of Si.... I Installed the passanger side, (done easy swapping out rails).... Here is my problem, The driver side of the si seats have these to ***** that adjust the seats to different position..(up,down and so on) How Do I remove these ***** with out braking them? I tried searching, I've been searching for hours. I'm stuck here.... Someone help me out...
Re: Need help with 00 Si seats!!!!!!!!!!!
I need to remove the rails, so I can swich them with the ones from the del sol seats... I cant remove the rails because I can't get those 2 ***** off..........
I'm sure someone removed them before...... I can get them off , its just that I don't want to break it....
Are you sure you have to remove the outside rail too?
On civics you just replace the inside rail & they line up after that.
Okay.. first thing is that is does not pull right out... You have to push the bottem part of the seat as far as you can because there is a clip and the end of the ****.. It tock three people the get this done.. it was a pain in the a. s. s..... But I finally got it and installed in the car. The seats look great....
HondaheadBigNick
11
12-12-2008 11:22 AM
JSPECHB
10
07-21-2003 01:50 PM
