GRS Tranny, B16a, Eg HELP
bought a car today, has a b16a in it professionally installed and a gsr tranny. Has a stage 3 competition clutch. When you put it in second it grinds loud and when you go to shift if you leve it in neutral and wiggle it and then go into 2nd it goes in no problem but it wont let you go in straight from 1rst...
What could be the problem...?
HELP HELP HELP FIRST CAR...
Thanks in advance
Thanks in advance
Re: GRS Tranny, B16a, Eg HELP
^^^it does the same it wont let you go in directly you have to put it in neutral and wiggle then it will go in no prob...
tried about everyway possble to get it in but you have to go in neutral and wiggle it so it can go in good...
If it is a synchro issue how do i fix that...?
Its not a minor grind its pretty loud...
So if i where to rebuild the tranny would it be better to get a new one or how much is it to build it...?
if after you change the fluid and it doesnt help, you probably have some syncro issue....that being said, you will definitely have to crack that open if you are confident enough to do that, or you can just opt to find another used/or rebuilt one, or even bring it to a reliable shop to do it....if you are going to buy one, try to find one w/ an LSD--ITR, CTR, or any usdm with an aftermarket one installed...do things right the first time so you dont regret yourself later
Thanks for the advice, what do you suggest the best fluid is for that engine...?
4th to thrid.. but he didnt have any grinding our loud noise issues.. so more than likely the OP has tranny problems..
spoolinegsr
06-14-2006 11:03 PM
