gsr swap into a 93 ex coupe
ok first off im swaping a gsr obd2 into my d16z6 93 ex coupe
my first question is
1)does the wire harness on the motor fit on the stock one that i have on the frame or does it need somthing else.
2)can i run the same ecu for the gsr.
3) or do i need to get the entire gsr harness instead of only the engine one.
and one more question what do i need to drop in a skunk 2 manifold on the gsr head
Re: gsr swap into a 93 ex coupe
1) Yes the GS-R engine harness will connect fine with your existing harness.
2) If you want to use the GS-R ECU that you have, you'll need an OBD1 to OBD2 (A or B, depending on the exact year of the engine) conversion harness. If you want complete plug-and-play, you'll need a '94-'95 OBD1 P72.
3) Just the GS-R engine harness will be fine, and will connect to the stock Civic "sub" harness at the shock tower.
As for the manifold: https://honda-tech.com/forums/acura-integra-6/blox-intake-manifold-how-install-1141806/
If you don't want to take my answers as correct, then why do you stop being lazy and do a search instead of bumping this thread over and over again.
https://honda-tech.com/forums/showpo...29&postcount=6
eknorcal
11-14-2005 10:23 PM
90sihbw89crxfrnface
03-24-2005 12:17 PM
