speedometer not working help!!
Old Feb 23, 2009 | 08:18 AM
exotik4doorcivic's Avatar
Default speedometer not working help!!
just got a full sir2 b16a rhd clip for my 93 civic 4dr because my timing belt broke on my ls
put the swap in and everything is good except no speedo so no vtec
the harness i used was from a obd2 gsr so i swapped over the altenater,injectors,and distributer
swapped out the vss from the one on the ls tranny, and one from a gsr tranny i had and both dont work
also if you look inside the hole where the vss goes the gear inside spins when driving
it worked great before the swap so cant be the cluster
any help??
Old Feb 23, 2009 | 12:09 PM
killerB16A's Avatar
Default Re: speedometer not working help!!
bump for a homie
Old Feb 24, 2009 | 08:05 AM
bump
EgLuv94
Apr 20, 2014 08:07 PM
haas480
Transmission & Drivetrain
May 29, 2010 03:51 PM
ghostcivic
Sep 3, 2007 09:50 AM
gassaversracing
13
Jun 2, 2005 07:23 PM
