B series swap mounts?
Im kinda short on my swap till i get my taxes back, but just wondering i got some stock motor mounts off of the swap i bought (b18c1) and also have my d15 mounts, which mounts could i use to get it running for now? The swap is a b18c1 goin into a cx hatch.
And also what mounts would be a good aftermarket swap mounts? Hasport?
Thanx!
Thanx!
Re: B series swap mounts?
A 92-95 hatch should use the 5 mounts that came on the B18C1.
It depends on what you want from the swap for mount choice. I'd only get aftermarket mounts if: 1) I was going to race it w/nitrous or turbo, 2) the stock mounts are completely shot, 3) I have some fillings I need removed (from the vibration). For something that isn't a dedicated track car, I'd just get the Energy Suspension inserts. The kit usually covers the rear mount and front torque mounts, and eliminates almost all motor movement, without the bone-shaking vibration.
or if you know some one with stock Si mounts from a 1999 2000 they will work but you need the bracket off the driverside of the motor as well...umm never mind wrong body style
you can use all the mounts off of a 94-01 teg...except maybe the banana mount in the back. but the rest should work. same with shift linkage...use integra linkages. so if you have the b18c1 mounts...that should work. i may be wrong about the torque mounts...but main mounts will work.
D16SohcVtec
08-12-2008 08:03 AM
integrawow
05-23-2007 11:16 AM
