New Yorkers: Passing inspection with JDM motor/ecu obd2
i have a 2000 civic with a jdm b18c. I have the p73 itr ecu but it is obd2a and my civic is obd2b. Can i use this ecu with a conversion harness to pass inspection? I cant use my usdm bseries ecu because the car wont run due to the lack of crank angle sensor.
I was also thinking of using a 99/00 CTR ecu as this is obd2b. Will the car run properly with the ctr ecu?
Any inputs?
Any inputs?
Seagull Management
Re: New Yorkers: Passing inspection with JDM motor/ecu obd2
Any inputs?
Any inputs?
*If* you are using an OBD2B USDM Integra ECU You will need to move pin A16 to A15 at the ECU and have the immobilizer removed and replaced with a dummy unit to prevent a CEL (H-T user Katman has a service where he will remove the immobilizer, PM him for more info). If NY plugs into the Diagnostic port for inspection you need a USDM ECU, as JDM OBD2 ECUs wont communicate with the diagnostic port.
yeah x2 on what they said, i some how pass with a jdm b16a2 i hook up my old d16y8 ecu and drive 60 miles to reset the **** real easy on it then bring it in, I'm not sure what was modded to do so, but the place that did it is www.synapseturbo.com give them a call and they could hook ya up cost me like 150 which is worth it.
Will the lack of ckf sensor prevent the car from starting with stock civic si ecu?
Also can he use the jdm distributor with the obd2b harness or does he need the obd2b dizzy as well?
Trying to get this guys car on the road
Seagull Management
Yes, although if its anything but a '99 - '00 Si engine harness you will have to swap the distributor plug on the harness ('99 - '00 SOHC civics [except HX coupes] use a different small style distributor plug)
UNforgivABLE
02-25-2009 05:16 PM
